I am wiring two existing pool lights for a friend/customer. I have not done any pools and want to make sure I have everything correct. I have reviewed 680 multiple times but want to make sure I'm not missing anything.
The lights are wet niche. The flex cords are stubbed in PVC above the ground outside of the deck area. The 300 watt lights are 12volt supplied from Safety Volt transformers.
I am going to install a pool juntion box on each stub. Due to the distance to the transformers I'm running #6 from each transformer to each junction box along with a #12 ground.
There is no bonding jumper coming from the light but as I understand it is not required for 12 volt lights.
The junction box can be located at any height above the pool as the lights are 12 volts.
Potting compound needs to be applied to the cord end in the junction box as well as the ground terminals.
The circuit supplying 120v to the transformers does not need GFCI protection.
Thoughts comments?
Thanks,
st1976
Thoughts comments?
Thanks,
st1976
