HappyFace
- cumberland furnace, Tennessee
I have a pool and where the pump is placed (above ground pool), which is which it pretty much has to be placed, the clearance horizontally from the pool wall is only 4 feet to the outside of the deck. The problem, I have a privacy fence, dogs, and want to box off this are with lattice or something to prevent the dogs from damaging the cord, pump, ect.. The minimum distance from the outside of the pool is 6' to place an outlet the feeder underground obviously 18" with UF wire. I have the codes, but will an inspect fail with an GFCI, locking, ect outlet at the distance I have to work with? If so can I keep it at this distance and use Liquid tight there is no mention of this in my local edition book (2008).
