malachi constant
- Minneapolis
I have a new installation: permanent indoor pool with adjacent (~10' away) spa. There are a half dozen 208V/1P 20A pumps. The pumps are located in an adjacent below-grade parking garage (within same building/structure), maybe 25' from the pool. For what it is worth we have a certified and very respectable pool designer on board to whom I am also floating this question.
FIRST QUESTION:
'08 NEC, Article 680, Part II relates to Permanently Installed Pools. 680.22(B) states: ?Outlets supplying pool pump motors from branch circuits with short circuit and ground fault protection rated 15 or 20 amperes, 125 volt or 240 volt, single phase, whether by receptacle or direct connection, shall be provided with ground-fault circuit-interrupter protection for personnel.? (This paragraph was new to the 2008 edition.)
Does the inclusion of "'ground fault protection" indicate that if there is no EGFP device, then no GFCI is required? The service to the building is 208V/3P, I am pretty sure there is EGFP on the main or elsewhere, so no GFCI required? Right?
SECOND QUESTION:
Part IV relates to Spas and Hot Tubs. 680.44(C) states: "A combination pool/hot tub or spa assembly commonly bonded need not be protected by a ground-fault circuit interrupter."
Anyone want to hazard a guess as to what constitutes a combination pool/spa? We have a pool. We have a spa. I don't believe the pumps are shared, but believe some other parts of the pool system (such as the chemical feeder controller) are shared. If the first question above negates the requirement for GFCI then this second question doesn't even matter, correct?
Thanks!
FIRST QUESTION:
SECOND QUESTION:
Thanks!
