JoeStillman
 - West Chester, PA
 - Electrical PE
Three 3HP pool pump motors rated for 208/230V, 12.4/11.2A are fed from a 120/208V, 1Ø, 3W panel, each on a 20/2 GFI breaker.  The breakers are tripping after the pumps run a little while.  Contractor has tried...
I'm going out on Monday to take some power quality readings. Wish me luck.
			- Replace breakers with non-GFI. Still trips.
 - Replace 20/2 with 30/2. Still trips.
 - Replace breakers with ones that have same label as pump/drive. Still trips.
 - Put an amprobe on the branch circuit. Pump draws nameplate current.
