Pool Pump Troubles!!
slopehi
New User
United States
Hey everyone,
I am trying to get a pool pump running off of a switch. Every time I flip the switch, the breaker pops. I've tried a million different things and I cannot get this thing to work. I may be overlooking something small, but I was hoping to get some help on how to get this thing wired.
Here's what I have got to work with:
I have the source wire coming into the box.
I have a 125v outlet running up to the source wiring.
At that point of connection I have the hot and neutral pigtailed and those lines running to the switch, connected with the corresponding colors.
From that point every time the breaker gets flipped on, the pump runs, but as soon as I flip the switch the breaker pops.
I talked to another guy and he suggested removing the white wire from the switch because it was causing a dead short. I tried that and the pump runs, but the switch does nothing.
Any help with this would be appreciated!!!
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
