Hey guys, I've got a couple of questions.
If a inground swimming pool has a Gas fired water heater (constant, thru circulation), 100% metal, and it's bonded to a common #6cu solid conductor that bonds all the pump motors and the Equipotential Grid, will this (legally and safely) suffice to bond the pool water?
When was the Equipotential grid requirement added to the NEC?
The pool in question has a bare #6cu solid coming up from the floor of the pump house, which I presume is connected to the deck/pool steel.
I'm unsure if there is a actual (qualifying) grid under the concrete deck.
Is there any way to check continuity between the pool deck and the pump motors, other that chipping concrete?
There are no ladders in this pool, only steps at one end.
As I type that question, I realize that it sounds stupid.:roll:
I'm working behind a complete idiot, and trying to make sure that this pool is safe.
The pool and deck are pretty old.
The "pool specialist" relocated the pumps and pool panel to a new location, didn't re-bond the pump motors and installed a (listed) 120V lighting fixture inside the pool without a GFI on it's supply circuit.
He apparently was the one who brought the #6cu solid into the new pump house.
There are too many things to list.
I've taken care of the bonding, pumps, heater, building steel and the #6 coming from (?) the pool deck.
All the plumbing is PVC.
My biggest concerns are the EQP and bonding on the light niche.
I guess that I'll have to take my swimming trunks and goggles to check the light.
The Grid....?????
Any ideas?
thanks
steve
The Grid....?????
Any ideas?
thanks
steve
