does the code require branch circuits that supply power to a hard wired pool heater be GFCI ?
I ins.GDF Member Jun 10, 2009 #1 does the code require branch circuits that supply power to a hard wired pool heater be GFCI ?
Dennis Alwon Moderator Staff member Location Chapel Hill, NC Occupation Retired Electrical Contractor Jun 10, 2009 #2 I don't see anywhere in the code where the heater needs to be GFCI protected. I assume you mean a heater for the pool water.
barbeer Senior Member Location Pinellas County, FL Jun 10, 2009 #3 680.9 does not specify GFCI protection. 08 NEC Last edited: Jun 10, 2009
J jusme123 Senior Member Location NY Occupation JW Jun 10, 2009 #4 is this is a permanently installed pool or storable pool?
