A potential customer has a new above ground pool that will need a gfi outlet on a wood post for a pump. Because of the distance from the house he wants to know if I can pick up power from his shed that is only 15 ft away.
He has 2 12/2uf wires running in the same trench together that go to a 2 gang switch box and one circuit goes to outlets and the other to lights.
Can I use these wires to set a panel in the shed 120/240v with a ground rod. Then come out of their and install a service outlet on the outside of the shed and then go to the pump outlet by the pool. I will make sure this wire that leaves the panel to go to the pump has an insulated ground.
If this cant work what other option do I have to use one of the circuits by itself and go to the pump from the shed.
