Pool wiring requirement
pmoney44
MASSACHUSETTS
I’m in the process of wiring a above ground pool and the homeowner wants the convenience receptacle on the backside of the same 4x4 post is the pool motor receptacle. I’m reading 680.22 A 1 and 2 and I’m reading 6ft minimum. So I’m guessing is ok to mount the circulation pump receptacle on one side and convenience receptacle on the back side??? Thanks in advance.
No reason not to as long as it is gfci protected and 6' away
