mickeyrench
- edison, n.j.
can anyone tell me if there has been any code wiring changes for above ground pools for 2008 ? i don't have a 2008 code book with me right now.
thanks
thanks
mickeyrench said:can anyone tell me if there has been any code wiring changes for above ground pools for 2008 ? i don't have a 2008 code book with me right now.
thanks
i just found out the pool has a circuit passing underground going to the garage . don't know how deep. any comments. thanksmickeyrench said:can anyone tell me if there has been any code wiring changes for above ground pools for 2008 ? i don't have a 2008 code book with me right now.
thanks
mickeyrench said:i just found out the pool has a circuit passing underground going to the garage . don't know how deep. any comments. thanks
680.10 Underground Wiring Location.
Underground wiring shall not be permitted under the pool or within the area extending 1.5 m (5 ft) horizontally from the inside wall of the pool unless this wiring is necessary to supply pool equipment permitted by this article. Where space limitations prevent wiring from being routed a distance 1.5 m (5 ft) or more from the pool, such wiring shall be permitted where installed in complete raceway systems of rigid metal conduit, intermediate metal conduit, or a nonmetallic raceway system. All metal conduit shall be corrosion resistant and suitable for the location. The minimum cover depth shall be as given in Table 680.10.
Dennis Alwon said:If this is a storageable above ground pool than I don't see where the bonding comes into play
Good question. I assumed that.electricmanscott said:Why would we assume that it is???
Dennis Alwon said:Because we know it is above ground from the op so the only other qualifier is less than 42" deep. Most above grounds I have seen are but I didn't assume anything. I just said IF.
underground wiring shall not be permitted under pool or within the area extendining 5 ft horizontally from the inside of the pool. u should look at 680-10.mickeyrench said:i just found out the pool has a circuit passing underground going to the garage . don't know how deep. any comments. thanks
sparky62 said:Hi Guys,
Glad i found a forum with pros.
Iwould be happy if some one can answer a question or 2
Question:1
I`am wiring a pool with metal walls,(in ground) my question is do i ground with bare or insulated #8, given the price of copper , i`am looking to cut my cost and still comply with code?
Question #2: I`am also installing a 100 amp sub panel from the main house panel, I`ll be using pvc to the pool panel , once i exit the house ,can i sleeve urd direct buriel Aluminum with a # 8 copper in the conduit or do i even need the #8 at all?
YOUR HELP IS GREATLY APPRECIATED!
