Popcorn, Asbestos, and Ceilings...
Fulthrotl
~Autocorrect is My Worst Enema.~
i showed up today to do the can light dance, and the painter
had just scraped the popcorn ceilings, and didn't bag the room.
popcorn, it was **everywhere**, including in the shag carpet
(circa 1970) that is due to be pulled up and torn away......
here's the deal... the ceilings are plaster, and gray in color...
no final white plaster coat, no paint, just gray plaster...
the house was built in 1960, so it's well before the Asbestos word was
banned in 1973.
my initial thought was that the house had popcorn shot on the
ceiling later on, and asbestos isn't an issue.... then i thought
about it a second... the only way the ceilings have no finish
on them is if popcorn was shot on initially, back in 1960....
meaning the popcorn is probably full of asbestos....
so... where do i get this crap tested? i also need to find out
if the plaster has asbestos, before i cut 4 dozen can lights in.
using asbestos in the final coat of plaster was common, as it
allowed the plaster to trowel out very nicely.... it wasn't common
in the scratch coats, cause it wasn't needed.
and, is my reasoning behind the ceiling sound for assuming that
the acoustic was sprayed when the house was built, or is there
another explanation that would allow me to leave the tyvex suit
and purple cartridge respirator in the van?
thanks for any info and experience you guys have....
FulThrotl
Fulthrotl
Dennis Alwon said:
The only real way to know if the popcorn ceiling contains asbestos is to get it tested. I did a search-- try this site
http://www.asbestostestinglab.com/testing.html
i did some googling myself, and came up with this one:
http://www.asbestostesting.com/index.html
they are in LA,
they do a same day testing and notification......
they do it annonymously, if that's a consideration,
and they aren't much money.... $30 per sample,
or $20 each for multiple samples....
off i go tueday with ziploc happy bags in hand....
appreciate the feedback... thanks....
FulThrotl
muskiedog
Minnesota
Look up asbestos abatement specialist in the local phone book. i deal with this all the time. Have two projects going right now. Old courthouse remodel.
Remember that with out testing you do not know for sure. There are a lot of materials that look like it but are not.
Probably though. It went into everything.
cowboyjwc
Simi Valley, CA
I never worry about...cough, cough, cough...asbestos. I'm sure that...hack, hack...it's all a bunch of.....Wheeezzzzeeee.....hype over nothing.
