Hey Guys I know a GFCI is not required for a porch mounted ceiling fan, but there is no reason I could not use one..right? I've heard of problems with the arc faults and fans. The only reason I am asking is because the power out to the porch now is GFI protected. So my dumb question is can I use the existing GFI circuit to power the fan? Also I will be installing a switch that controls the light and the fan. Do you guys see anything wrong with this. I will also be mounting a light on the outside entry of the screened in porch. Thanks for your input.
