mrmike
- Adirondacks,NY
if you have a 3 phase Generator on wheels feeding a 3 phase load on wheels will there be a difference in ground potential between the size of them? Should there be an earth ground rod installed? Where would the neutral wire which is center tapped from the generator be hooked up load side even if know Neutral is needed for the load??? The neutral & ground are jumpered at the output of the Generator...........
