chinookwind
- wasilla,alaska
i wired a new house with a 200 amp transfer switch for a potable generator the inspector said i have to switch the neutrals what code does this fall under? code book referance 445.20 but my code book only goes to 445.19what is the purpose for this and how do you ground the generator neutral since on a portable generator the neutral goes back to the windings and the only ground lug on most portable generators is for the frame only, where does the neutral ie grounded conductor get grounded
