MDS75
- arkansas usa
Installed 30 amp 4 wire recep and used interlock on a square d meter/combo panel. Have not seen generator yet to see if neutral is bonded to frame but if so my understanding is the neutral and ground need to be split on generator frame because the neutral is not switched and It is not a SDS. Since neutral and grounds are bonded in panel I need to break bond in generator or am I wrong on this?
