Portable Generator connection
Does a generator terminal require 90c rating?
A test I recently took implied that a lug terminal on a portable generator should be AL9CU rather than plan AL/CU. This is for a non-emergency site generator not connected (usually) to a building. I get into this stuff for events held away from power supplies. I've been poking around trying to find something that says anything about it one way or another.
Any references?
I was asking if the terminals need to be 90C.
No, you would be hard pressed to find a 90 degree lug in most any piece of equipment.
And every other connection would have to be good for 90 degrees also.
