Portable Generator for Water Pump Setup
Ioannes
New member
Hello,
I'm looking to power my 240V water-well pump with a portable generator during power outages. The water pump is inside a small shed and is powered through a subpanel located in the same place. I was thinking of simply wiring an outlet in parallel with the pump on the load side of the pump breaker in the subpanel. Then, when the utility goes down, I can open the breaker, and plug my generator into the outlet. I would also shut off the breaker at the main panel which is supplying the subpanel.
Do you think this would be in accordance with the NEC?
Thanks for any advice.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.
I agree with the action taken to close this thread. But I am going to use my Moderator?s privileges to open it just long enough to add one comment.
For the record, NO! This is not in accordance with the NEC. Not only is it forbidden, it is extremely dangerous (probably the reason it is forbidden, I should think). This type of setup has cause the deaths of too many utility linemen already. Please do not add to that tragic statistic by creating another death trap.
