Every install is different, and the things you mentioned are part of what makes them different.My main issue here would be fumes, window and door clearance
I've got a 50 foot cord for mine, I started out with a 30 foot but to use that one I had to take t out of the building I had it in and put it under my carport.
now I just have to pull it out into the floor of the shed plug it in and start it! I have a capped PVC nipple in the wall that I pull the cord through.
I'm going to eventually put louvers in the doors of the building (8X14) so I can shut them and run it if I have to. Maybe even an exhaust fan......![]()
If it isn't a permanent installation Does NEC really apply to it? A "power inlet" is a permanent part of premises wiring, the generator and any cord that connects to it not so much. There are places that have a transfer switch(and may or may not have some sort of inlet) and no generator, until they have a need for one.I would say that might be a violation of 400.8(2)![]()
Not only that but when the power is out and the (portable) generator is running I'd say the cord is temporary wiring. The inlet is permanent wiring.It might be, but when the cord is pulled through the wall that means the generator is running and power is out and I'm not too concerned about an inspector showing up and telling me to take it out.
When it's not in use the cord is inside the building rolled up and the nipple is capped.
Oh, and in 2017 that has become 400.12 (2)
