Hi,
I installed one of those Reliance 10-circuit manual transfer switch portable generator hookups. It comes with a 30 amp twist lock inlet box that the generator plugs into. I fed the inlet box with 10/3 Romex.
After I installed it, I wondered if I should have installed a 30 amp 2-pole breaker to protect that 10/3 feed, because there is nothing to protect it on the manual transfer switch side. Maybe the generator has a fuse that protects it?
Is it necessary to install such a breaker to protect that feed?
Many thanks for your input.
Joanna
Joanna
