Breezlybru
New member
- Farmingdale, NJ, Monmouth
I have seen many posts regarding generators with neutral bonded to frame and whole house wiring. All posts generally explain how you have to remove the neutral/ground jumper to convert the portable generator to a floating neutral. It is actually a service bulletin from Honda. While kicking this around with some tech's one floated the idea of installing an amp applicable spst toggle
Switch with a lockout frame. Switch closed neutral bonded to frame, switch open floating neutral. I couldn't seem to convince him otherwise. Any body have an opinion on this.
