mark32
- Currently in NJ
I can't find the thread, but someone asked when using a manual transfer switch that does not switch the neutral, the generator's neutral and equipment ground should be isolated. Now, what happens when, under generator power, you have a line to ground short. The fault travels to the generator's frame and then what happens? As I see it there's no path into the generator itself in order to trip it's OCPD.
