Hi all! I'm having some trouble wrapping my head around this one. I have a 5wk portable generator that I'll be hooking up to a ProTran2 generator subpanel/transfer switch. I'll have an inlet on the house with 3-wire ran to the generator panel. And 30A 2 pole from main panel to feed the generator panel. My question is where do I keep the neutral bonded?
My instincts tell me keep everything bonded in the main panel. Bring off a ground and neutral into the generator sub. Of the circuits I'm moving to the generator panel, move the neutrals over but keep the EGCs in the main panel. I'm certain that the generator will be bonded, so keep the subpanel unbonded. Since, while on generator power, the generator breaker is acting as the 1st disconnect (bonded), and the subpanel would be unbonded.
And while on regular power, it's still acting as a subpanel so unbonded neutral within is still fine. Just hoping I have that right. Thanks.
