Hello All,
I want to connect my portable generator to my home which has two Square D "QO" panels - the main panel is 200A with a second 100A add on (aux) panel. Both panels have built-in main breakers, are located next to each other and are individually connected to the service entrance. The service entrance is located about 6ft to the right of the panels. I only want to feed the 200A panel from the 12kW generator via a 50A breaker where I will selectively manage which loads I need during a power outage. I don't need an ATS since I plan on starting the generator and doing the switchover manually. I was hoping to use a mechanical interlock on the 200A panel, but am not sure how to best safely (and legally) disconnect the aux 100A panel. I have a 200A ATS that was bought years ago when I was originally considering going with a fixed whole house solution. I wired the entire house when I built it 30 yrs ago under a homeowner test/permit so am familiar with all of the wiring.
I will attach a photo once I have that option (this is my first post).
Thanks for your help!
