mjgilmore54
I am installing an 8 space generator panel next to main service panel .I am going to put a power inlet on the outside of the house in order to plug in a portable generator when needed. The generator is 8kw running watts.Panel is rated 100 amp and power inlet is rated 30 amp 120/240V.
I was going to run a 10/3 romex between the gen panel and power inlet.Inspector said it has to be in conduit but I cant find that in code. Has anyone run into this? ? Thanks
