- Bremerton, Washington
- Master Electrician
Portable generators intended to use a power cord and plug into an inlet come in 2 flavors, floating and bonded neutral.
The floating neutral would be used with a non SDS transfer switch to prevent objectionable current and keep the GFCI on the generator from tripping (if I understand it correctly)
Question 445.20 A for an floating neutral, 15 and 20 A require GFCI, how is that GFCI wired? Also a provision for the 15A & 20 A to be interlocked with 250V outlet
Question What type of generator are you finding commonly, floating or bonded? Do your customers understand this or do you just wire it up?
