Begin Rant.
I've been doing a lot of "in the weeds" look at portable generators lately. I'm talking the small ones...8KW or smaller...with one or two 120V receptacles and perhaps a 240 30A L14-30.
I've looked at the NEC, UL, and OSHA. I've explored various manufacture's Q&A on grounding/bonding, their instructions, and a good bit of posting on forums such as this as well as some technical sites.
They are ALL eff'd up in one way or another. There are so many things I just can't bring myself to list everything wrong or misleading, or convoluted to the point of incomprehensible. But EVERY ONE has some flaw.
Most of us here are technically inclined. Professionals. God help average Joe Generator. Navigating a simple answer is nigh impossible.
The silver lining in all of this. As eff'd up as the explanations (and requirements and regulation) are, the raw configurations of our portable generators provide at least one layer of fault protection from electrocution. And if GFCI's are employed, there are actually two layers of protection. The bonded neutral/ground generators will clear equipment faults via the EGC. Floating neutrals, while not able to clear a fault, require a second fault to close the loop. Ironically, in the latter case, a ground rod is actually MORE DANGEROUS, as it aids the closing of the second fault loop. Yet OSHA requires one for a Float Generator!!? But I digress.
The reason the small portable generators are 'safe' when used properly is not because of the mush of instructions, guidance, and regulations that one must follow to make them safe. They are safe because they are safe (if used properly)...out of the box.
I'm not really asking a question. Just ranting. Ranting that NEC, OSHA, (I'll defer UL for the moment) are crap when it comes to small portable generators. Add to that the crap from manufactures instructions, and their help sites, and the myriad "tech" websites.
Rant Over. Carry on.
