mkgrady
- Massachusetts
I have a customer that has a storable pool. He wants to heat the water enough to take the chill off. He has purchased an 11KW heater for it. Hayward Model # CSPAX11. That seems like a lot of heat for just raising the small pool temp up a few degrees but that is not my question. I'm not finding any requirements in the code for a pool heater except the disconnect for it would need to be 6' from the pool. This heater is not portable equipment so it is going to have to be hardwired. It looks like he plans to just leave it sitting on the ground with the water filter hoses running in one side and out the other. It all seems like a bad idea.
Let's say he can permanently mount this fixed equipment heater in a way that I can hardwire it. And let's say he has the heater, wiring, disconnect six feet from the pool. Is there any reason this set up would violate the code? I see a typical lug on the outside of the case for connection the solid #8 bond wire but there is no equapotential bond because it is a storable pool. This all just seems wrong.
