I have a PD which is used for Rock shows. This PD is portable, travels the country and is bound by UL-1640, NEC 590.
I wish I could attach a picture but cannot,, anyway
The PD has 4 rows of horizontal plates. Each plate has (3) breakers and (3) L6-20 or (3) L6-30 receptacles per plate. So One horizontal plate, (19"long) = 3 CB's and 3 receptacles. The manufacturer will not mix the L6-20 and L6-30 receptacles on the same horizontal plate, will not give a code ref, just will not do it. Question: If I change the breaker, associated wiring and receptacle will I violate any part the of NEC code? What I want to do is change one of the horizontal panels to have (2) L-620's and (1) L-6 30. Thank you in advance for any advice.
