I've been asked to hookup a portable pump motor with an on motor shutoff switch. The motor is 120Vac, capacitor start design and was requested to have a 25ft. cord attached. I've looked in the NEC2005 edition and have not had much luck on finding portable pump applications. It will be used with flexible hosing in indoor and outdoor areas and can't promise that the person using it will use GFIC protection. I believe this is not allowed, but, I can't prove it through my research so far. Can anyone help with this? Much thanks if you can.
