portable pump protection
John Powell
New member
I have a 460vac 3 phase pump with a manual starter (Nema 4 enclosure) I want to use for pumping oil from one tank to another.
I want to be able to plug or connect this into any suitable 3 phase 460 vac supply around the plant, using proper connection means.
I have overloads on the starter, and the pump runs at about 3 amps.
The SO type cable I will be using is good for 20 amps. It is 20 feet long
This is for an industrial application.
Do I need GFCI protection? Can I use only the circuit breaker at the panel (20amps) to properly protect this pump and the operator?
I am thinking I will need additional circuit protection (besides the overloads) at the pump. Is this true?
John Powell said:
I have a 460vac 3 phase pump with a manual starter (Nema 4) I want to use for pumping oil from one tank to another.
If this is indoors and not a "wet location" I don't see why.
Yes (actually its protecting the wires, grounding the pump protects the operator)
No, wires are protected by 20A breaker, motor is protected by the overloads, if it is cord and plug connected that can be your disconnecting means, if not you can install a breaker lock (assuming it is within sight of the pump)
