electricguy61
Can someone explain to me the reasoning behind installing a grounding grid under a concrete slab installed for a portable spa (where by design there is no exposed metal)?
Also, where would you connect the bonding wire on the equipment? The lug on the pump motor? The grounding conductor bar? Couldn't doing so induce a fault current (if the bonding grid is a better ground source then the main grounding electrode)?
I've read the code numerous times (680), but it doesn't seem to make sense to apply it to portable spas. Many inspectors on the forum seem to think it does.
Thanks for the help.
