I've read a ton of threds on this site and others about grounding portable generators and welding machines. We are in the process of rewriting a safety manual and I have a question that seems stupid:
If you have a welding machine or generator on skids (not vehicle or trailer mounted) is it required to earth grounded if using attached recepticals for powering tools or lead for welding.
What is the difference between a "portable" generator that can be moved by personnel and one a thousand pounds heavier if both are used the same? Confused
Thanks grove
Thanks grove
