roger said:
smart, cord and plug connected items are not part of the "isolated power system equipment"
I see you choose your wording wisely, as "cord and plug connected
items" are [almost
] always referred to as "cord- and plug-connected
equipment". If only the CMP chose as wisely I/we wouldn't have as many misinterpretations...
Isolated Power System Equipment... all electrical systems have supply equipment and utilization equipment. Take either out of the picture and no system
"Hey, guys, I have power on this receptacle!" Let's plug our equipment in here. Darn, the plug don't fit... must not be permitted on this
system."
Isolated Power Supply Equipment... any confusion in this terminology? Hmm... I wonder, how long has the term "Power Supply" been around?
Seems more and more that CMP's want to coin new phrases while they're making
Code and relying more heavily on supplementary documentation than ever before. Is it just me that sees this?
Anyway, while we're on the subject of isolated power "systems", perhaps you can clarify 517.160(A)(5) for me. It appears there is no provision for a 4-wire system. It says the third conductor for 3? is yellow then it goes on to discuss 125V recept's with orange always on the typically-grounded terminal. Then, the way it reads if a 1? supply, brown is connected to the "hot" terminal... for 3? either brown or yellow on the "hot". So where's the provision to utilize the third phase? If it is "
125-volt" 3?, you can't use brown and yellow to power a "
125-volt" receptacle. So what's the point of even mentioning 3? unless the receptacles determine the color of conductor and what circuit or buss they land on in the panel has no bearing?!!! I'm confused.
BTW, can anyone clarify this without having to resort to or draw on their knowledge of supplementary documentation?
