Possible defective 4" new construction recessed housing
fcfjr
Santa Rosa, California
Electrical Contractor
Has anyone had a problem removing the inner housing cylinder of a Halo 4" H995ICAT in order to access the junction box? The older design allowed you to insert your hand inside, make a fist and twist and pull down the inner housing. This latest design does not allow you to twist the inner housing, if you pull down the tabs just dig into the housing. Tech support was not open over the weekend but will be calling them on Monday.
