kush_ee
- New Jersey
- Electrical Engineer
Hi everyone. This is a solar equipment related question. These pictures are of the internal cables (factory installed) inside a string inverter – 1500 VDC, 600 VAC. Some inverters had catastrophic failures which led the client to shut down the entire site and perform detailed inspections of all units. During inspections, this type of discoloration/sweating/condensation was observed in these cables in almost all inverters. In some instances, more damage was observed where one of the cables had completely burned up. Any insights into what exactly might be causing this? Have you seen this type of discoloration/ sweating on conductors in any other application?
Our initial suspicion is on moisture entry into this cable area which may have caused oxidation/corrosion over time, which increased resistance and caused an overheating. Another possible cause might be a manufacturing defect where the factory installed undersized cables.
Full load AC current - 127 A at 600 VAC
Full load DC current - 178 A at 1500 VDC
