The other day i was troubleshooting a 110vac solenoid circuit and read 99 volts on the de-energized circuit with a digital multi meter. I got an ideal solenoid voltage tester (wiggy ) and with that I read nothing.
I figured I was good, but when the wires rubbed together there was still kind of a nasty looking arc there.
I was wondering your thoughts on the potential that still existed in between the levels the DMM read and what the wiggy read.
There is the solenoid tester part of the wiggy and there is also a neon(?) lamp.
If neither "light up", is there definitely not enough power there to be concerned about?
