Are we talking about motors here or not?Pick up is when the capacitor is cut out what is drop out.
Potential relays are the small motor starting relays. Is that what you are
referring to?
If so drop out would be when the motor can disconnect the start winding.
what does drop out mean?
Pick up and drop out is referring to the state of the coil and operating armature, not the state of output contacts.
Pick up is when enough voltage is present to operate the armature, drop out is when voltage is too low to remain holding the armature.
