teslafan01
- Seattle, WA
The solution shown in the image you posted is correct. It looks like what you've got incorrect is your power equation. Power is voltage squared divided by resistance. Your basic power equations are:I always learned to divide the bottom number first. R= e^2/p. Maybe someone could shine some light on the subject?:?
I use RxV=P
so 5.51x208= 1146 watts.
so 9600w-1146w=8454watts
I am confused.
You shouldn't. You had the guts to admit you didn't understand something and ask for help. I've met plenty of people who would just assume they were right and there was a mistake in the solutions manual. They are the ones who should feel like idiots.Thanks, I just feel like an idiot now. :ashamed1:
But I can empathize with you anyway. I think we've all done something similar. Glad to help.
I agree you should not feel like an idiot. The problem today is with online courses and books. They cannot replace good ole fashion classroom instruction and homework. In a classroom room you would have been lectured for a several hours s on Ohm's Law over a period of a week and would have worked several hundred equations as homework after class. If you did not do it, you would not understand or passed the class. You cannot learn much from a book. It takes experience, passion, and money to learn.Thanks, I just feel like an idiot now. :ashamed1:
As Eric Clapton once wrote in a song, You have been told, now it is time you learned.![]()
Actually, that is technically perfect. Indeed it is exactly what I just showed, except that I skipped the middle steps and went straight to the end.The way Ive done it is converting 9.6kw with 230volts to ohms. The use the ohms value given with 208 to give the new kw rating.
Not technically perfect but it gets you there.
The principle of parsimony perhaps?Actually, that is technically perfect. Indeed it is exactly what I just showed, except that I skipped the middle steps and went straight to the end.
It works because if you take 208 and divide it by 230, and then square the result, you get 82%. So you are doing the same thing that I did.For a quick and dirty answer I have always taken the 230/240 volt Kw ratings and multiplied by 82%. . . . I know it is not exact but it works
You know, I remember the 82% but not how it came about till you mentioned it--I just learned it a long time ago and stayed with itIt works because if you take 208 and divide it by 230, and then square the result, you get 82%. So you are doing the same thing that I did.
Please note that if the item had been rated at 240 volts, and you plan to run it at 208 volts, then you should use a factor of 75% instead of 82%. Why 75%? I will leave that as your homework assignment. :happyyes:
