i haven't designed power for duplex outlets in a few years. in an NEC class i learned that you can't design outlets using triplets (a triplet being three hots sharing one neutral and one ground all run together in a conduit). I learned that you must run seperate circuits, i.e., one hot with one neutral and one ground for ea circuit. here is my question: what do you do when you have system's furniture with a 5 wire harness (which requires circuits, 3hots, 1N, and 1gnd) or an 8 wire harness (4 circuits)?
