Power Distribution Blocks
JFritz001
Looking for some help here guys.
Is it ok to double tap lugs on a power distribution block ?
I work in the entertainment industry. We use portable power distribution panels. I am currently looking to rebuild a portable power distro and looking to feed a handful of sub panels from a main breaker panel ( within the same enclosure ). These use a chassis mount style breaker such as Square D QOU style breakers.
To feed the sub panels, I need to use a distribution block. My issue is pretty much all of the distribution blocks have a 1 or 2 wire primary in and no more that 6 to 8 secondary out's. Is it ok to double tap wires from these blocks ?
power distribution blocks
Yes, by double tapping I am refering to two wires into one secondary hole of the distribution block.
