Re: power equipment uses
The unit "KWH," or kilowatt-hour, is a unit of energy. Power is the rate at which energy is being used (or generated, or transmitted, or whatever). So if you know the equipment's rating in terms of power (watts), then energy (kwh) can be found by multiplying power times the amount of time (in units of hours) that the device is running, then dividing by 1000 (to convert watt-hours to kilowatt-hours).
However, if you only know the equipment's rating in terms of current, then solving the problem requires one more step. But that step can take on four different forms, depending on the type of equipment.
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Single phase, non-motor: Watts equals volts times amps.</font>
<font size="2" face="Verdana, Helvetica, sans-serif"></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Single phase, motor: Watts equals volts times amps times power factor.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Three phase, non-motor: Watts equals volts times amps times 1.732.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Three phase, motor: Watts equals volts times amps times 1.732 times power factor.</font>
