tallgirl
- Glendale, WI
- Controls Systems firmware engineer
I'm looking at a contract where we will need to develop our own power factor correction setup, vis a vis, utility capacitor bank switching.
What is the best of the rip-off power factor correction gadgets? The idea is to set up a number of inductive loads, measure the power factor in real time, then have the gear enable and disable the previously mentioned rip-off power factor correction gadgets to get back to unity on the power factor. Whenever the angle changes from lagging to leading, turn the power factor correction thingy off. All the while, increasing and decreasing locally produced power.
For bonus points, if any of y'all have a favorite Modbus enabled revenue grade meter you'd like to recommend, that would helpful. I've looked at this one in the past -- http://www.gepower.com/prod_serv/products/metering/en/utility_revenue_meters/kv2_multifunc_elec.htm -- but it's more than I want in an electric meter, which prolly means it is going to cost more than I want to spend.
(And for the terminally curious, PV systems are notorious for making utility power factor worse since PV inverters produce near-unity output and don't produce KVArs on their own. Thus, the PoCo is providing fewer KVA while still providing all the KVArs ...)
