Hello all,
Typically what do you use for PF when doing voltage drop calculations for a typical commercial building from its switchboard (480/277) to the subpanels? Nothing crazy, typical LED lights, Receptacles, Offices setup, step down transformers to 208/120V, and A/C. Is .95 reasonable or maybe even Pf of 1 since it is mostly resistive load?
Thank you
Thank you
