jerjwillelec
- Nevada, IA
- Master Electrician
I've been asked to meter the power factor for someone...I've never done this before. Any suggestions on a decent power (factor) quality meter?
Power factor metering and power quality metering are not synonomous. Be careful of your specifications.I've been asked to meter the power factor for someone...I've never done this before. Any suggestions on a decent power (factor) quality meter?
That's a good question. I am a very small business owner (2 employees including me) /electrical contractor...been in business for 6 1/2 years...and I am trying to grow some. As I said, I've been asked to measure the power factor but at this time don't have any details on what they are really wanting. He simply asked if I was interested...which of course I am but unfortunately don't know a lot about it...as I primarily have been involved in residential contruction...
Can you tell us why this guy wants his PF measured? What type of equipment? How accurately?
Whether power factor or power quality this is something you don't just jump into without some knowledge of what you are working with. First you need to know what they are concerned about before you know what you will need to monitor.
That's a tough question, as there are many things to consider. If you just want to check PF to a single 1 phase load I guess the cheapest way would be to buy an inexpensive watt meter (like an Extech or Amprobe, about $350) and just compare the VA to the watts and do the math. If you want to check, say, a service or 3 Phase load it gets a little more complicated as to be accurate you need to measure from all 3 phases at once and you are getting into a much more expensive meter which typically includes some level of PQ function. I happen to use an AEMC 3945 as it is fairly comprehensive, but the down side is it is about a $4000 meter.I've been asked to meter the power factor for someone...I've never done this before. Any suggestions on a decent power (factor) quality meter?
Hahahaha...you would think I knew this wouldn't you??? Unfortunately...I don't know much about it. All I know is it has something to do with wind turbines, and obviously capacitors. I think their POCO is telling them they're PF is too low and they want a second opinion???
How large of a wind power installation?
If wind turbines are also backfeeding POCO there should not be power factor problem, you have power factor problems with inductive loads - primarily motors and magnetic lighting ballasts.
Bigger problem with co generation is to make sure you are in phase with the POCO.
What if he is generating with induction generators, they need reactive power from the line or else a cap bank to function
No experience with this, but I kind of see what you are getting at.
