I am a little bit confused. Why 95% PF is better than unity?
The main discussion was about PF - central and distributed compensation. I have mentioned the device that I am selling just as one alternative (and I must say a good one
) for distributed reactive energy improvement. It is fitted to motors, according to the motor load. It changes the way the motor behaves and in any way does not turns into capacitive range. Other solutions include adding local capacitors, selecting different loads etc.
The problem with reactive energy is that it causes losses, both for the utility and the site itself. This is correct for large facilities - not residential site, which have minimal losses.
The affect of harmonics to energy measurement is very complicated. It is correct that mechanical meters do not measure all the harmonic power, but the extra losses harmonics create are much higher. Note that the active power in harmonics is very small. For example, if you have the maximum allowed harmonic pollution (depends on standard being used) of 5% in the voltage and 20% in the current, the power will be not more than 1%. If the pollution is in different orders - not even this. The extra losses for 20% current harmonics are much higher. Moreover, utilities around the world move to electronic meters which measure all the harmonics.[/QUOTE
Well harmonics are not measured with a watt meter and i think a little harmonics can save on the bill more as it chopps it up and the meter can not measure it .
