The power factor will change depend on what motor is doing. It could, for example, be pump load.By using a VSD (variable speed drive), would the changing of motor speed changes the original power factor for the same motor ?
From your reply it seems no direct relation between p.f and speed. Thanks..... which may or may not be related to speed. But PF on the load side is irrelevant beyond the VFD itself.
