I have a 115 volt motor that draws 20 amps with 86% power factor = 1978 watts how many watts kw does the meter read?
I must not understand the question, for it seems trivial to me. The meter should read 1978 watts, or 1.978 KW. What am I missing in the question?
Motors are never 100% efficient.
The mechanical power out the motor shaft, when converted to watts, will always be less than the electrical input in watts. And that input power will always be less than the input VA.
Tapatalk!
The motor is using 2.3 kw but i only get 1978 watts in hp?
I have to agree with Charlie, if watts is what is being asked for - it is right there in the question - no calculation necessary. Could be kind of a trick question to see if you are paying attention to details.I have a 115 volt motor that draws 20 amps with 86% power factor = 1978 watts how many watts kw does the meter read?
Hmm... a watt-hour meter does not indicate "watts kw". :blink:Well, yes, if and only if the meter is in fact a watt-hour meter. I guess you have to assume something to make the question answerable.
Although this does appear to work, he would have to be reading a kVA meter, not a kW meter. I think it could just as easily be coincidental and that his motor is 86% efficient, which is right in line with many single phase motors that size.No. The motor is drawing 2.3 KVA. 2.3 KVA x .86 = 1978 watts or 1.978 kw.
