This question is in regards the Power Factor Correction. I received from our power company a spreadsheet, upon my request, a yearly study of our power usage. This was broken down into monthly usage for 2003. On this spreadsheet they show kWh, Actual demand kW, Actual kVA, and Power Factor. After reviewing this information I seen that the majority of the time we had a low power factor (86 to 89). On the same spreadsheet they also show in Kvar the amount needed to correct the power factor to 90 percent for that peak demand during that billing cycle.
I know were our problem area was in our plant in regard to power factor correction. We have two 250 hp compressor that had no power capacitor on them, which base on our P.F. and to achieve a P.F. of 90 percent plus we installed on each compressor 75 Kvar. We have a PowerLogic meter and how we have a P.F. of 91 to 93 percent.
I would like to know what formula did the power company use to figure out that monthly Kvar correction needed to obtain the 90 percent P.F. I?m trying to do a cost comparison between before capacitor were installed and after.
Thanks
rmonroe
Thanks
rmonroe
