No.merriar said:If I have a poor power factor on the primary side of a transformer, will the poor power factor be reflected on the secondary side?
Richard
Richard
rattus said:It is the other way around. In an ideal transformer, the PF seen on the secondary will be seen on the primary as well because the secondary load is reflected back to the primary. Therefore, the lag seen in the primary will be the same as seen in the secondary.
weressl said:Plus the additional inductance from the transformer itself.
rattus said:True Laszlo, but note the assumption of an ideal transformer.
