power factor
mryan
determine the flc of a 30 hp,3 phase, 230 volts,synchronos motor with a 90% power factor. 63*1.1=69.3 How do you get 1.1
Finite10
Great NW
Off topic: I like the beer analogy to understand power factor. Pour a beer, the head is the power factor. But the POCO can only charge for the liquid part and the foam does you no good at all.
Efficiency = power output/power input
Amps = 746*HP/V*1.732*eff.*PF (assume perfect efficiency?)
Table 430.250 far right side of table - as stated above - see the * for 90% = 1.1 multiplier referrence.
Perfect power factor is 1 so I see your question mryan. Good luck.
